Well since one of the local 4x4 spots was dried up my buddy in his Toyota sporting 4" of lift and 33" tires decided that the river needed to be conqured. This river has a nice fairly hard-packed sand bottom and since nothing is flooded now it runs quite low. He started out on a sandbar and was cruising along, went head-light deep in a hole and came right out- impressing everyone of course. Then he went into another hole and didn't quite make it out. Luckily he was on his way up out of a hole when he started to dig, and he ended up with his bed underwater but his carb was still free and clear (barely.) Being the only other functional 4x4 there they called on me to pull him out. Hmmm...My Jeep has no lift, new 31x10.5" Dueler MTs in front and almost bald 31x11.5 Wrangler ATs in the rear.... Also it doesn't idle since I just did an HEI conversion and can't get the timing advance right and I still have the Carter BBD in there screwing things up. But hey- I've rigged a snorkel up! However my rear PCV vavle is missing . I also had the parking break on the whole time- the light for some reason wasn't working this one time to let me know! Well I did drive down to him (fun fun!) and stopped in the nearest shallow spot that they could reach with the chain (yes a chain so no snatching.) The nearest shallow spot happens to put the water over my transmission hump. After pulling him out (go Jeep!) he did an oil change with all the oil we managed to scrounge since some water had gone down his carb, THEN I checked my oil to find it milky.... It wasn't SOO bad so I drove home the 40miles like that keeping a close eye on the temp and oil pressure gauges. Well now I need to know what I have to do to clean it all out of my engine, someone said to put a quart of ATF and a quart of Diesel into my engine and run it like that for a 5 minutes and then drain the oil, water, diesel, atf, etc out. I'd like to hear some better ideas if you have them, I dont wont to pour ATF into my engine, its bad enough in the x-case!
BTW I'm ordeing a Webber and hoping to have a mechanic get the tuning and timing adjusted so no more idling problems! Need to replace my front seal as well it has been dripping oil for a week
