THE BOLTS ON THE END OF THE SWING ARM - LOOSEN THE LOCK NUTS - SCREW IN THE BOLTS - WHICH WILL MAKE THEM STICK OUT LESS - I FORGET WHERE, BUT THERE ARE NOTCHES ON BOTH SIDES TO HELP KEEP BOTH SIDE EQUAL - YOU'LL HAVE TO LOOK FOR THEM - YOU PROBABLY KNOW NOT TO GET IT TO TIGHT - IF NOT LEAVE ABOUT 1/4 OF PLAY UP AND DOWN IN THE CHAIN - MAKE SURE BOTH SIDE ARE EQUAL - RETORQUE THE
LOCK NUTS - ANY OTHER QUESTIONS JUST REPOST THEM I'LL HELP YOU AS MUCH AS I CAN
ZIZAG400EX - EX-WARRIOR GUY
