A note on that compressor to manifold bracket
If you use the Edelbrock Performer intake manifold, this bracket comes up a little short . . . if you use the post 1984 360 brackets out of Cherokees and Waggies. It can be installed as-is, but you must gradually tighten the mounting bolts (on both the compressor mounting bracket, as well as the compressor to manifold bracket. The problem with doing this is that it angles the compressor slightly, and causes a slight misalignment with the waterpump pully and the alternator pully, as well as some increased wear on your v-belts.
There is no real easy fix to this; the compressor to manifold bracket is stamped so thin on the outside edges of the bolt holes, you aren't left with much room to re-position holes, and you can't move the aluminum bolt tower on the Edelbrock manifold . . . so you are kind of stuck. I noticed on one of the Jeeps sitting outside of John Lloyd's shop had a fix to this problem. Upon questioning the Jeeper, I found that he fabricated a square bracket to place on the top of the compressor, extending the rear of the bracket to accomidate a second set of bolt holes. This allowed him to stack the original bracket on top of the fabbed one . . . the catch to this is that the original bracket has to be re-bent to allow for the increased angles.
I just said to heck with it and bought an extra set of belts. Although I didn't specifically point out the slight misalignment to him, it passed muster with TR on his recent visit to southwest Missouri. I got his official shade-tree-mechanic-know-enough-to-be-dangerous seal of approval on my engine work.
