Does anyone have a crank pulley, crank timing gear, bolt and woodruff key from a 1.6 that they would want to part with so that I can resurrect Hummuzuki from the dead?
All Good Medicine,
Crow
Creator, everything we do leaves a track. May our tracks be ones we would want you to see and others to follow......
Best I can do is send you a whole set from a 1.3 and you can see if it will work for you?
I have 3 engines around at this point. IF you are v-belt then you would just need the bottom.
if you are serpintine belt I could send you everything. Let me know asap I could maybe send it today
If i get a response before I leave for work.
Glenn
87' Zook Spoa,M/L 33's, 4.16 tcase,4.62 gears Camo,Header,2"exhuast, Cam.
Lockers, 8klb winch, -Wildweasel2 NE4WI- club http://www.cs.umass.edu/~glenn/personal.html
