I do not know very much about what comes stock on a Wagoneer but I know that Scouts come with 44's all around if you get the right year. I was just wondering what the list thought about swapping out axles from a Wagoneer vs swapping out from a Scout or maybe from both would be best. I was just wondering if there was any benefit to swapping out one over the other. I know that you can swap from either, I do not know much about the Wagoneer though. I was told that you can swap out the rear AMC 20 out of a Wagoneer and the walls of the shafts are much thicker than a stock 20 out of a Jeep. If you spot welded the tubes at the joint on the carrier I was told that this would be stronger than a Dana 44, bigger ring size also. Is there any size difference between the 20 and the 44 that affects ground clearance, one better than the other? If you have to move the spring perches for both axles, can you just reset them for the proper driveline angle needed for the amount of lift or is there a limit to either axle for how far a person can rotate it to achieve proper alignment? Is there any way to get four wheel disc brakes all around with either swap or a combo from both vehicles. Which axle is closer to the length of a wide-track Jeep axle? I was just wondering if there was any preference from one axle to another.
Lee R. Byrd
Lee R. Byrd
