Guest
·I just got some new spring perches and before I start welding, I want to make sure this is right. Right now there is a 10 degree angle difference between the pinion and the transfercase with the jeep unloaded, but sitting on the springs. The angle between the transfercase and the drive shaft is 11 degrees.
What I am planning to do is weld the new perches so that the pinion and transfercase are exactly parallel. I believe this will increase the angle between the yolks and the drive shaft, but not by much, maybe 12 to 13 degrees.
Does all this sound right?? The guy I bought the perches from said not to worry about the 10 degree difference and that my vib is prob coming from somewhere else. But it just makes too much sense that the difference in angle is causing the vib. He also said I should lower the transfercase with shims. I've never heard of this with a 1980 CJ7 and a 2.5" lift.
Also, the rear springs only have about 30 road miles on them, none off-road. Should I change any of my angles because of this. I bought the jeep non-running with this lift already on so, I'm not sure how much actual lift it is producing right now.
Any thoughts??? I dont want to do this again, twice is plenty.
Bill
Bill
