Badbowtie3:
Sheeeze, this is a big post!
The best way to explain would be with pictures & arrows, but that won't work here.
I'll explain this assuming you know what a cam does, and the basics of a valvetrain.
A hyd lifter has a hollow center that holds oil it receives from the oil pump. The cam lobe is touching the outside, or "body" of the lifter, but the pushrod is touching the "plunger" on top of the lifter. The plunger can be pushed down into the body of the lifter, but with oil pressure fed into the hollow lifter from the side of the body, the plunger pushes up. When you adjust a hyd lifter you tighten the nut on the rocker arm 'till the rocker arm is just barley snug, then tighten another 1/2 turn or so. This extra turn forces the plunger onto the lifter a little bit. Now with constant oil pressure you will have a lifter that will maintain a "tight" (zero play) valvetrain, but not enough to effect the valve springs. Now a hyd cam w/ a hyd lifter rides in contact with the cam lobe all the way around. When the cam lobe comes along and pushes the lifter, it's really pushing the lifter body, the body is pushing the oil, and the oil is pushing the plunger. The oil does leak out of the lifter at a controlled rate, but the cam opens/closes the lifter too fast to let much oil out. The oil pump replenishes what little oil escapes before the next cycle. The plunger can go up and down to compensate for wear on the valve seats or wherever and still maintain a tight valvetrain. In fact, that’s the whole point.
Make sense so far????
A major problem in hyd lifters is at higher rpm the lifters can “pump-up”. This happens if there is play in the system from an unstable drivetrain, usually from weak springs. Like “seat bounce” when the valve bounces off the seat after closing, or maybe catching a little air off a lobe. What happens is while the valvetrain is loose for this split second, the lifter fills with oil in an attempt to fill the gap. The problem with this is when the valve is supposed to be closed now, it isn’t. It’s got that extra oil in there holding the valve open a few thousandths. There goes your power.
A solid cam uses a solid lifter, as in it does not move at all. It is basically the same as the hyd lifter, except the thing is plugged up inside with a steel insert, or machined so the plunger can't move down. With this set-up you will need some play in the valvetrain to compensate for wear and thermal expansion. This is done by simply making the whole valvetrain loose. This is done by adjusting the rocker nut down to snug, but you use a feeler gauge between the tip of the rocker arm and the top of the valve when you do this. This clearance left after adjustment is called “lash”. A common lash (determined by the cam manufacturer) is .022”, which was made by….. you guessed it, a .022” feeler gauge.
The typical solid cam itself is different because of the shape of the lobes that were ground on it. The very beginning and ending of the lobes start out very slowly in comparison to the hyd cam lobes. This is to slowly take up the slack “lash” in the valvetrain to avoid a violent collision that will damage components. And the closing ramp eases the valve down on the seat to avoid pounding the seat and valve bounce. “Tight lash” cams work on the same principle except the lash is much less, maybe .012”. But you have to keep closer tabs on your lash because when you wear down to zero it will hold the valves open, there goes the power again. Also a tight lash cam is less prone to poor performance if the lash is not exact. If you have say .015” on a .022” cam, then the valve will open slowly at the beginning of the ramp and give you the same problem a hyd cam has. If the lash is right where it’s supposed to be the cam will take up the slack, start flexing the valvetrain just about ready to open the valve, then it should hit the aggressive part of the lobe.
Running a hyd cam with solid lifters is the ticket in my book. You need to have lash .010” or less to avoid valvetrain damage. It is quieter and does not have the transition ramp for lash so you never have worry about losing power. You just have to keep an even closer eye on lash to avoid getting near zero. I’ve been running lash for 8? years now, and I have yet to find it out of adjustment. I usually don’t go more than 5K miles, but the lash is always where I left it.
I sometimes run Rhoads lifters on my cams (both solid and hyd) those are the lifters that bleed out so much oil that while it’s holding the valve open, the plunger is pushed down a noticeable amount. It’s designed to do this to reduce overlap and duration at lower rpms. This bleed-down function all but gone at high rpms because it doesn’t have time to bleed out.
Between running lash and Rhoads lifters, you can have a big cam that is very tame at idle.
Whew! my fingies r tired. Let me know if anything doesn’t make sense, or you have any questions.
And get this book! It can explain all this and much more!
Here's the book, typed as it appeared on the cover.
Motorsports International
Powerpro Series
How To Build & Modify
Chevrolet
Small Block V-8
Camshafts &
Valvetrains
By David Vizard 1992
Amazon.com. carries this book.
Chevota
