Will the amc v8s bolt up to my manual trans(peugeot ba10/5). I know that the older 258s and v8s are pretty much interchangable. Will this trans hold up to light use?
87 wrangler(258)
The bellhousing bolt pattern is the same, you will need the proper V8 flywheel for you displacement engine or get the 6 flywheel rebalanced with the motor. The trans isn't noted for its strength, but if you baby it, it may last long enough to save for a more HD trans. Hope this helps. good luck.
Other things you need to do are fab your own motor
mounts frame & block both sides, fab exhaust...no
headers available, re-core your radiator to 4 cores
and have the proper upper rad. hose nipple installed
to match the thermostat housing.(makes it alot easier to find a hose to fit)
