If you're planing to install large off-road tires on your JK don't forget to take care about gearing and protect your differential, because this part is often being damaged in tough off-road conditions. A set of high-quality axles, able to handle extreme abuse is a must-have for your rig and G2 Axle & Gear Core 44 Rear SAE Axle Housing is one of the best options available! Utilizing the strongest, latest generation high pinion Dana 44 gear design, this housing is build to the heavy loads that would normally bend your stock axles.
Main features:
- Fits 2007-2014 Jeep Wrangler JK
- Designed to deliver trouble-free, consistent performance
- Made with laser-cut and CNC-formed steel brackets
- Heat treated aluminum differential cover
- UV-stable black power-coat finish
- Features Metric Carrier Bearings that allow use of factory air locker
- Easy bolt-on installation.
Watch this video to find out more about Core 44 Axle Housing by G2 Axle & Gear
G2 Axle & Gear® - Core 44 Rear SAE Axle Housing
G2 Axle & Gear Core 44 Rear SAE Axle Housing is designed to meet the highest demands of true off-road enthusiasts. PM me today for a price quote or leave your inquiries below.
Main features:
