/wwwthreads_images/icons/smile.gif Luckily for all of us, one of my oldest moonguys/wwwthreads_images/icons/crazy.gif was at Indy in the Heyday of the Offy-powered roadsters, and he STILL has "unsprung weight" as a mantra. HIS explanation is that in order for the chassis to "work"....for the suspension to do all that it is supposed to do about cornering, about getting traction, about distributing weight where it is supposed to be.....the weight HAS to be ON the suspension/wwwthreads_images/icons/crazy.gif.....as in compressing the springs, shocks, etc. Otherwise it may as well be on someone else's Jeep. Moonguy's/wwwthreads_images/icons/wink.giftheory is that unsprung weight is bad even in rock crawling because it keeps the chassis from adding weight, just when it is the most critical. That's why the automakers(Hummers included) has tried so darn hard to get the gearboxes off the axles and ON the chassis. They even went to INBOARD brakes to reduce unsprung weight on hot cars that need to corner real good. This IS a difficult concept, especially if you don't have a lot of race track time like mooney here and I have, where you have had a chance to watch the car "work" and try different things. We always refused to run HAlibrand Quick-change rear ends(Man...does THAT date me or WHAT?) because they were so heavy and added so much to the unsprung weight of the car. We opted instead to carry two different transmissions with slightly different gearing and between that and tires, we could usually get what we needed./wwwthreads_images/icons/smile.gif
