Hey Everyone,
Is anyone running a tuff country ez ride lift? I am looking into lifts and their setup seems pretty good-teflon inserts, etc. I am not going
to be loading my jeep down so I don't want anything really stiff (ie procomp).
Has anyone looked at the "fitment guide" at the Natl wheel and tire site? I am wondering if there is any accuracy to this guide.
They say that a stock CJ should be able to fit 32's while a stock wrangler will fit 30's. I am pretty sure my CJ won't fit 32's right now (stock).
thanks and keep on Jeepin'
CJay
'84 CJ-7 sort of..87 YJ body replacement under way
I'm running with Tuff Country's heavy-duty 2" lift (don't know how old it is). The ride is very rough. I called the company and was told that my lift is 15-20% stiffer than stock.
Can't tell you anything about their softer setup.
"Those who expect to reap the blessings of freedom must undergo the fatigue of supporting it"
I also have the tuff country 2" heavy duty lift. I wanted firm because I tow a camper (must 4-wheel on vacation). I had 32s on before the lift and found the bump stops a few times wheeling. The tires tucked in the fenders (didn't rub) but since I put a full-width early Bronco 9" in back the lift keeps metal from meeting rubber.
Maybe your springs are totally DEAD
my 85 bone stock fit 31/10.50s easy w/tons of room.
33/12.50s fit w/ 1" front shackles and onlt a real mild rub on the rear at some odd angles. You should have plenty of room with the 2" lift for 32s.
85'CJ7 258 4" runnin33's
my freind runs the Tuff Countrys 3.5" lift it is very nice, the springs seem to be really soft, the ride improved greatly when he switched to the tuff country from a 2.5" Rancho system and flex is pretty impresive even though there shocks are a little short and my freinds kit did not have bumpstop extensions so the 33x12.50s got a little freindly with the fenders, this caused some noticable damage to the front fenders but the rear was easily fixed with a littl fender trimming that you can't even notice unless you were looking for it
Jeff
'83 Toyota long bed
"look Ma no doors!"
