truck won\'t go... mud in clutch?
We took the Bronco 2 out and made it almost out of a hole but dug in and stopped right as the front end started to leave the hole. After backing up and hauling arse forward a couple times, the tires weren't spinning when the clutch was let out even though the engine revved. There was a slight feeling like it wanted to go, but it wasn't getting enough power to the tires to spin them. I pulled him out and let it sit for a couple minutes, then it was able to drive off but every time he shifted it felt like he was riding the clutch for a second once he got back on the gas, even though he wasn't.
I thought maybe mud was stuck in the clutch so we took it to a creek crossing and got grill deep, but then the truck wouldn't move at all when the clutch was let out and I had to pull him out. Once it was out, he was able to drive it home and said when he hit the pavement in 2LO he said it felt normal again. Does this sound like mud in the clutch, worn clutch, or resistance coming from one of the axles/brakes?
