Just wanted to ask if there's a special trick to removing the birfield off of the axle shaft?
I believe Chris has popped a shaft at the splined end. We have several axles lying around with broken birfields. Figured it'd be easy to swap out the shafts & keep the good birfield with rings. Haven't torn it apart yet, wanted to ask the ?? before I go get dirty.
Pre-shate it,
Brad.
Pre-shate it,
Brad.
