I have a 360 with the GM400 transmission out of a 75 J-20. Will at Turbo 350 bolt up or what do I need to do to make one fit?
The TH-400 from a Jeep is a different bolt pattern than a Chevy. I would say no, unless you use an adapter of some type.
'86 CJ-7, 360, TFI, 727, OEM Dana 44 rear w/Truetrac, Dana 30 w/Powertrax No-Slip, 4" Superlift, 4:11s, Warn HS9500i
depending on what the 350 was out of, if it was bolted to an amc engine then you would be set there but the output shaft might be different, advanced adapters will tell you any adapters you will need if any for the swap.
Jeeps are Built not Bought
