i'm doing a build up of a 84 cj7.i plan on a 350 and a turbo 350 trans.i need to know what transfercase to use.i don't want a np203, and a np205 .its going to be a stock 350.i 'm going to use it for 4 rated trails.thanks
-=C/MAN=-/wwwthreads_images/icons/cool.gif
Dana 300 is the stock 1980-1986 T-case and the adapter made by advance adapter for the TH350 is 399.99 from Four Wheel Drive Hardware. You can get advance adapter products from most 4wd companies. Four Wheel Drive Hardware also sells the advance adapter Atlas II t-case if you have more money and want the best t-case. It costs $1895 for the 3.8:1 ratio and $2295 for the 4.3:1 ratio.
Tim Springer
1980 CJ7
