Transfer cases for a NV4500
443 Views 2 Replies 1 Participant Last post by  JEEPN
I'm planning on installing a NV 4500 (probably) into my CJ7 and I am probably going to have to use the Dodge version of the NV 4500. I am having trouble finding a Dana 300 to use and I was wandering what else would work. Will a Dodge or Chevy NP 241 work to and how tough is the t-case? Also what is the low range gear ratio? Will a NP 205 from a Chevy or Dodge (possible later version) bolt up? Are there any other t-cases? Thanks.
Tim Springer
1980 CJ7
See less See more
Other than the Dana 300, I only know of the NP 241 like you mentioned. Unless you want to buy adapters.
The LO range in the NP cases should be 2.72:1
_____________________
John
95.5 YJ with "stuff"
http://SonsofThunder4x4.com
I have a spare D300 kicking around if you're interested. It's in Maine though. E-mail me off-line if interested.
JEEPN
'81 CJ-8 Scrambled!
