Guest
·I have an 88 wrangler that I just can't fix. ATF fluid is leaking out of the transfer case. It leaks out of the rear output, right where the driveshaft goes in. I have replaced the rear output seal three times and have replaced the oil seal further in the case once. I was extremely careful the last time I did it so I thought for sure it was fixed. But sure enough after driving for about 10 minutes, I parked it in the garage, and it was leaking again. It is not a small leak either, it leaves a puddle 6 inches around in a matter of an hour. I just cant figure out what else it could be. And I don't want to get a fixed yoke output because I am selling the Jeep in a few months. If anyone has had this same problem please help, I don't want to give in and take it to a "profesional" to fix.
Dan
Dan
