I have a 1977 Chevy 3/4 ton 4x4 350engine NP435 trans, 205 case. My trans and transfer are going south on me and I'm contemplating my options. I have a spare 208 case, but I'd lose the durability of the 205 and have to change driveshafts, and still need transm. repairs... My real question is that I have access to a 79 Ford bronco parts truck, 351M-435 trans, 205 trans- will the FORD and Chevy trans/transfers interchange if I use my bellhousing? The mounts look the same, but I can't find any info to tell me yes or no.
Brad
You can get adaptors that will make them bolt up, but they won't just bolt up. I never heard of those trans and t cases going south. The trans is a very heavy duty unit, and the 205 doesn't get too much stronger. You sure you don't have other probs?? Clutch, or something in the drivline??
no the will not.
the make them just i little different so you cant change them around.
but mainly the front drive shaft is on the wrong side.
I could be wrong, but i have never heard of a NP 435 in a chevy truck, only SM465's. What characteristics are they giving you that you think they are going out? If you do indeed have a NP 435 transmission I don' know if your spare tranny will swap in or not, but the t-case from the ford definitely will not since it would have a left side 4x4 drop.
I do know it is a 435, synchros and bearings are pretty well shot, this was originally an oil well service truck for years, then was run as a mud bogger, then I got it and use it as my work/camping vehicle (regularly hauls 2+ tons of materials) generally overused and abused and I was just trying to find a cheap swap out option, rather than take the time to tear down, order parts and rebuild, also, I think the transfer shift shafts are worn out as it won't hardly stay in Low range. I can use the 208 because I have compred the adapters and they interchange, and I'm pretty sure the input splines are the same - the 208 is just about 6" inches longer on the rear output side, wich meand I need to shorten/replace my rear shaft.
Thanks for the inputs though- more food for thought.
Brad
