Guest
·I have a 86 Ford Bronco setup as a pre-runner with fiberglass at all corners 4in lift it used to be a rancho lift but the only part that is rancho is the trailing arms and front drop bracket which will get replaced with cut and turned I beams. I am also running 35x12.50 BFG KO and 4.10 gears with a 9in trussed Currie rear end 31sp. Also a AOD automatic trans with a cooler. Now my question is has anyone heard of whereing out the fiber clutch Disks in under 18 months after a complete rebuild. Line pressure and everything else looked good no problems no burned oil even??
This is a new one on me. I replaced the clutches and it works great for now but I still can't find the original reason for the problem. Yep thats my project bronco in progress.
Plans for the future include a full cage front to rear, 4 link rear coil over setup and coilovers up front also. I also want to swap out the 302w for a 351w.
