The tranny in my CJ just crashed - I believe it is a 999 and the TC is a dana 300. I'm interested in the possibility of putting in a different tranny. The jeep is used as a driver and also used on moderate off-road -MOAB, Black Hills, Sawtooth. The automatic has worked pretty well even through the 31" tires have put alot of stress on it. I'm comfortable taking on a rebuild if that seems like the best direction to go, but really interested in the BEST Options that might be available at a reasonable cost. Thanks,
Actually you already have a pretty darn good trans. I would go with a rebuild, auto trannies are not the big mystery some people
think they are. I would stay with the trans you have, possibly with a different valve body to make it more efficient.
Brad
ORC Land Use Section Editor
Get involved or lose it all, the choice is yours!
If partsmike advice is of interest to you, you might want to look at his post on 3-8, @22:30, 'What did the TF 904 come in?' Apparently, your trans has a pretty good reputation, and Mike's suggestion/post is to consider the non-lockup valve body and converter from the 904, combined with your 999 trans. Your 999 apparently has a preferred, slightly lower, first gear. Unless you have a need for something really 'beefy', I'd suggest keeping what you have. Off-road, or on, it certainly out-performs the factory manual trans' (obviously, my opinion, but based on many years of experience).
Best wishes.
Thanks for the advice. I will rebuild the 999. I must admit my skepticism about turning it over to a tranny shop without being able to tell them exactly what I want them to do. It may be a growing mistrust of someone else touching the old CJ. I understand from the posts that it would be beefed up and more efficient by going with a different throttle body and by using a nonlockup torque converter.
I understood that the lockup torque converter was helpful on the highway to reduce slippage. Is the disadvantage of a nonlockup that it is less fuel efficient at highway speeds?
Any other changes that I should consider in rebuilding the 999?
Off Roading Forums
