I just picked up a "universal" trailer wiring kit at Trash Auto. The manufacturer is "Hoppy" and the kit is for "vehicles with independent bulb turn signals and break lights" wwhich I think is correct of the 'finders. There was no vehicle specific application for the Pathfinder.
Has anyone ever installed one of these no cut/no tape/no soldering type wiring kits, is there anything special I should look out for? or is it as easy as the maker would have me believe?
Brian Oberle
95 Pathfinder XE
I have not installed one on my path yet, but did put one on my Ford Pick-up
and it was really simple. I just pulled apart the connector at the rear of the
vehicle put in there tee connector in and that was it.
If the has the correct splice connectors you should have no problem. I would be sure that you have the correct wire in the truck B4 you squeeze the connector. With a test light check that the wire does what it is supposed to first, ei: right flasher, left flasher, brake..
If you have the correct wire follow the instructions, and it should work fine
got it
I ordered a model specific tee connector form Cabelas (made by Reese). I haven't installed it yet but it looks easy enough. Shouldn't be a problem once I get done procrastinating.
Brian Oberle
95 Pathfinder XE
