Guest
·I have a 96 geo tracker with a five speed. My clutch pedal engagement heigth began to drop and consequently, shifting became difficult. I adjusted it back up at the cable adjustment on the clutch fork at the bell housing and regained proper shifting. I suspected that the clutch cable was frayed in the housing and "stretching" so i replaced it also. However, the pedal continued to drop and finally, this adjustment made no difference and I had to shift with NO clutch. The clutch pedal arm is welded to a rod that has the cable attachment bolted on the other end of the rod. After much detective work and even replacing the clutch assembly (CHILDREN DON'T TRY THIS AT HOME)I discovered that the weld holding the pedal to the rod was defective and had finally broken in the end. I've removed the assembly (a real nightmare because you have to take out the computers and then you have very little room to work) and re-welded the pedal but it broke again within a few miles. Has anyone had this problem??? Is there some fix out there other than welding the pedal back to the rod? Can a hydaulic system be retrofitted without much work?
HELP!!!!!!
HELP!!!!!!
