They are the same.
If you are wiring something that did NOT have a Motorcraft ignition, you will need the resistor...
If you are wiring something from scratch, and you want to use the Motorcraft ignition, you will need the resistor.
If you are upgrading something that had a Delco breaker point ignition, you will need to remove the factory resistor, and place one of the recommended resistors in it's place.
If you are just doing the TFI coil upgrade, and using the factory wiring, and you already had the Motorcraft ignition system, you do NOT have to use a resistor... There is already one in place...
If you have your wiring harness apart, and your Jeep is more than 15 years old, it's a real good idea to go ahead and replace the resistor wire, just because of age alone...
If I didn't have the wiring harness apart, I wouldn't worry about it...
Attached is the diagram again....
