Help
Can any of the junk yard scroungers out there near big junk yards find me the items listed in the sentence that follows from the North Coast Off-Road technical article except for the carburator. I don't mind paying for the items and your time. Tired of a cold weather idle of 3000 rpm until the old Zuk warms up....
I've got a new rebuilt carb....
NEED from 1978 Toyota Corolla 3K-C 1.2 earlier or later with same motor ok as well I suspect...
throttle cable bracket
throttle return spring
throttle return sping bracket
& the fuel line inlet to the carb....
Thanks.... Oldfartzuk....
When you get your carb, if lucky enough to find one in a junk yard, you need to get the carb, the throttle cable bracket, throttle return spring bracket, and the fuel line inlet to the carb.
