Why is it only 4200 pounds when the 5.9 with the automatic is 7150. My truck is 2001 Quad Cab 1500. Should the off-road package increase the tow rating?
Thanks, Andy
Premium Member
You got me. The off-road package sits higher but as for towing I don't think it should matter much. I forget whats in the off-road package but it shouldn't make a difference, unless it has no aux.tranny cooler but for a 5-speed...? I thought the first gear is very low on those just for towing/pulling so you won't burn out the clutch.
Do you have to upgrade to the 3/4 ton package to get the 5.9? If you do then that's the reason for increased rating. /wwwthreads_images/icons/crazy.gif
Tim "Sandman"
ORC Land Use columnist:
My May Column
Well this one time I pulled a 16' landscape trailer with 4 quads in it: a sportsman 500, a scrambler 500 4X4, and two 400EX's oh and my old blasterin the bed of my truck. The only time my truck complained a little was going up steep hills. all that weight has to be pushing 5000 lb's.
I have some picks i'll see if i can find them.
'98 Ram 1500, Gibson cat back, K&N, 5" Skyjacker, 35" SSR's on 16x8 Eagle Alloy's
