The Blaster has a 45 watt stator. It can't handle anymore then that. Most likly your fog lights are 50-55 watts each, so it can't power one. No you won't blow your CDI out. The ignition and lighting are two entirely different systems.
Sure you can add a battery. But there is no way to charge it from the bikes system, and with a battery that will fit in the batttery box and 100 watts of lights, you got maybe 20 minutes of lights.
Good tip on the LT handle bars.
Check out BC for some good mods.
YFS200
YFS200
