To my surprise 16valve coolant leak...help!
602 views 8 replies 6 participants last post by  Tusker
Well, my install went great and the truck has been in the garage and hasn't move for a week. I went to swap off the tires today for the impending yota swap and saw coolant on the garage floor. All hoses were dry, but behind the water pump and under the manifold is went.....Any ideas? I hope this doesn't cost much to fix, all my money went to the swap and yota's. I thought the engine was fine...till I saw this.
Koko
Is it the weephole leaking on the waterpump ? Maybe the thermostat housing ? Rent a pressure tester and pump it to 15 psi and you will see where it is leaking . Sorry to hear about your motor trouble , hopefully it isnt too serious .
#6 ·
Yank them. The tube in back is held in by 2-3 bolts and then you just yank it out (towards the back of the motor)
there should be 1-2 small hoses coming from the intake manafold to them, one of those may be leaking. You did hook up and tighten the heater core lines right?
(This pretains to the 8v's for sure and I "Think" the 16v is like them.)
#9 ·
I think you mean
In reply to:
can't beat the service from Aftermarket4x4!!!
[/ QUOTE ]
Glad to heat you got it diagnosed. If your engine is like the 1.3 and 8-valve and has the rubber o-ring gasket in the rear of the wtyaer pump where the collector tube 'plugs' in, I would change that too. I didn't and mine started leaking there a few days after I changed the water pump
