I am having problems with my 98 TJ shifting from 1st to 2nd when my Jeep is cold. I've had it to my dealer about 5 times. They changed out the syncros once and changed out second gear and the syncro another time. The latest is that they are going to put synthetic oil with additive. They have said the Tech Hotline advised that there is nothing they can do. Has anyone else had a problem like this?
yeah, I have. The AX15 transmission, from what I've heard on this board, is noted for that problem. Awhile back, I took mine to the dealer a few times too. They even went so far as to replace the whole unit!!! Thankfully, it was all covered under my 7 yr / 100,000 mile warranty so didn't cost me anything. Guess what? - same problem with the new one too! Just goes to show how much some dealers know about their own products I guess - cost the insurance company some $$$ for no good reason though.
Chuck
1995 YJ 4.0 5spd, 3" body lift, 32" Bridgestones (w/damn 3.07 gears), Durabak
Apparently a common problem. It helps to double-clutch when shifting from first to second with the transmission cold.
As far as a cure, I don't have one. I changed to Mobil 1 75w-90 synthetic gear oil in the transmission and diffs, which had helped in our Samurai. It helped the shifting of the AX15, but not as much as I'd hoped. I changed the transmission back to a non-sythetic 75w-90 when I found out that the '98 AX15 isn't supposed to use a GL-5-only gear oil. I changed to Redline MT-90 synthetic gear oil (75w-90) a few weeks ago. It made a bigger difference than the Mobil 1.
I still often get a catch when shifting from first to second, and occasionally when shifting into third. I try to "feel" my way into the gear instead of forcing it. I've got 35k miles now. It seems to shift better if I'm pulling a trailer, and/or if I'm letting the engine rev a bit more than called for by the "Shift, stupid" light. Note that I'm running the factory 30x9.50 GSAs with factory 3.73 gears.
Bill
