Guest
·I need to replace a part for my ignition switch,which is inside the tilt steering.I have gotten past the turn signal switch.Now I can see the part I believe is broken.This part connects to the linkage rod coming from the switch located on column.This rod is not connected, as this is how we start our 87 Wrangler.Looks like I would have to disassemble tilt assembly to replace this.Has anyone had to do this?Hurry before I forget how to put everything back together!
