I'm thinking of buying a 78 or 79 i forget what year it has golden eagle on the hood it's in pretty solid shape. can u guys tell me a little bit about this jeep it has 304 with headers I'm told it came factory. can u tell me what axles and transfercase came with this jeep. thanks
304 option (might be standard on the Golden Eagle)
I've never heard of headers as an option from the factory.(not likely)
Are you in a smog taxed state? Should be air pump and lines attached to the exhaust manifold.
Transmission would be a T150 manual.
T18's were not an option with the 304 but are a bolt in swap
Transfercase Dana 20
Front axle Dana30 w/power? discs
Rear AMC 20 Tracloc limited slip was an option
Ratio standard 3.54 option 4.??
Check the frame rails on the inside behind the engine where the springs attach. This is a common spot for fatigue/rod/cracks
