Gemmuns:
FYI, on stock 1968 Jeepster with auto tran. Pressure line for a.t. cooler is located on driver side of radiator. If you know this, you only have to cut one line to install cooler. I will be using my radiator tranny cooler to first warm up the fluid, then cool it with the Hayden Super cooler before going back into the tranny. Still have to do a little fabrication, but things are looking up. Hope this info helps somebody doing a similiar project.
BTW a radiator tranny cooler does not warm up the fluid. the temp of the engine
coolant by the time it reaches the bottom of the radiator can be anywhere from
80deg to 150deg depending on the temp outside. witch is still cooler than the 200 to
250 deg that tranny fluid can get.
