Larry,
I have a favor to ask. Would you mind hooking up your old coil and seeing what the difference is? I took off my HEI and went back to the Duraspark. I had done the mod about 4 years ago, the only difference is the coil. I'm still running the stock one. Right now I think the HEI gives me better all around performance, however, the Duraspark does have a couple of advantages.
1. The solenoid controlled PCV valve only works with the Duraspark hooked up. Without it, the idle is too lean and high.
2. The carb servo only works with the Duraspark.
Overall, my jeep runs well with the Duraspark, but I feel it runs even better with the HEI. Especially in the mid to upper range. I will be curious to see what difference the TFI coil makes. At this stage, I don't won't to spend money on it if its not going to make a difference.
One last thing....and please don't think I'm trying to start another issue. I have tried both ported and manifold vacuum, and it ran better with manifold vacuum. I'm not trying to question the vast experience out there but if you examine how the vacuum advance works and how timming is related to 'detonation', I think manifold vacuum is the way to go. I am doing more research on it and will post the findings when i have them.
John......southern CA
