Re: TFI COIL?? (resistor?)
If you have been following this thread, you will note that there are two 'camps' on the issue of resistance in the TFI coil primary circuit. If you follow Aaron (TR), you will go with the resistance. If you follow PM, you will go with straight 12V, no resistance. Since this all came up, I have been measuring the resistance of a BUNCH of coils. For coil primary resistance, I am seeing around 1.1 to 1.4 ohm for Duraspark coils (stock, with the DS module), and I am seeing the 0.4 to 0.45 ohm, as Aaron reported, for the Ford TFI coil. I have seen a few reports, here, that people have tried to run the TFI coil with straight 12V, and no problems have been reported (that I am aware of). Take your pick on resistance/no resistance. I believe it's obvious that the conservative approach is to add a little resistance to the primary circuit, if using the TFI coil. By adding resistance, the DS module should be happy, and there should be no issue about letting the smoke out.
Accel coil... I have no idea if it does, or does not, need a resistor. If it were for me, I would be looking at its cold primary resistance, and its 'in-circuit' (hot) characteristics, and going from there on whether to use an added resistance, or not.
bobH
