OK guys, I've been guarding the news as long as I could, but I'll spill my guts tonight. I've been waiting until I'd had a chance to wheel with it, but that day comes in about 8 hours, so this isn't too early. Venturing into what seemed to be uncharted territory, I bought a set of TeraLow 3.15:1 Low range gears (15 spline) to fill up the Dana 20 behind the Jeepster's TH400. My good friend Mel volunteered to do the build as I was a virgin to cracking open this kind of box /wwwthreads_images/icons/blush.gif and he's done gearboxes, diffs w/ ARBs and whatever else there is. After a couple of afternoons in his shop doing lots of watching and some helping, and with the gears happily and finally inside, I think I'd take on the project myself if I did it again on another rig /wwwthreads_images/icons/cool.gif. The complexity isn't so much what to do, but in putting the pieces in in the right order so a seal or a bearing doesn't have to get yanked out because you forgot something.
Probably the most important thing that is not addressed in the JP article on this conversion, or the Tera instructions, is they don't tell you that the new intermediate gear., which is larger than the old one, will have a clearance problem going in the case. The case's bottom opening, where the old intermediate gear nearly touches on removal, should be marked as the old gear comes out, so you'll know where to grind for clearance for the new gear. Neither the Tera instructions or the JP article mention this area needing grinding at all. You can't get the new intermediate gear in without taking out about 1/8" or more of the casting, from the case's machined bottom pan surface, all the way into the case, for the full width of the teeth on the gear. We discovered this after the other parts were in so lots and lots of care was taken to shield the inside from the grindings and a ridiculously redundant cleanup was done to ensure no grindings were left behind. I wished I had my Digi-cam when we did this so I could give a better pictorial, but I just got it a few days ago.
If you don't have a second T case and adapter as I did (thanks Brian!), you'll want to have the 400 to D20 adapter out and on the bench to assemble and test the case for gear clearances when you're doing the build.
With the new case built (having a spare, I left my 400 to D20 adapter on the Jeep), the replacement of the new output gear in the adapter is a snap. I would advise that the case be in 2 High when mating it up to the 400's adapter. I'm sure most of you veteran Jeep builders know this already, but this was my first (and she was sweet /wwwthreads_images/icons/smile.gif) T case surgery. I had to figure this out when the gears wouldn't shift and bound up. I had the 400 w/ the T case out last month, just days before the RAID, but I hadn't had the guts spilled until this project. I also left the D20's rear output gear/yoke case off which made lining up the gears of the case to the adapter easier because I could see inside. Once the case is bolted up, the rear shaft/yoke assembly goes up easy and you're home.
It's a little stubborn working the shifter through the gears before the drive shafts are in and the case is filled. Like in real use, a little rocking comes in handy to find the "spot". I figured I'd leave it dry until it shifted in/out without too much effort, just to make sure something wasn't in wrong ....although I had all the confidence Mel did it right. Really. Everything worked fine so it was time to fill it and close it up.
After it was full of 90w, some jack stand test driving was done in both Low and High range 2 and 4 wheel with he Jeep still up in the air. There doesn't seem to be much more (if any more) noise than with the stock gear set at least without a load. After 20 minutes or so of jack stand testing, all the bolts were re-checked and test drive was in order.
So far it's been out on the road in 2 High for an afternoon of errands and around the neighborhood in 4 High and 4 Low with the hubs unlocked. 4 Low is pretty whiny, but I didn't take any decibel readings before the swap to compare to. Maybe I should switch cases out and do that. I DON'T THINK SO! /wwwthreads_images/icons/crazy.gif
Thursday's the maiden voyage up around Rollins Pass, James/Kingston Peaks (for those of you in CO) and any trails around there where we can give the new gears a good workout. It's not Mt. Blanca or Iron Chest, but it'll do for a first run. Sure, I'll baby it a bit at first, but I really will get a chance to test its crawl-ability on several trails. Even better, Mel's going in his Jeepster convertible too so I have my "builder" and some "tech support" on hand should any gears puke out the bottom (cell phones get a good signal at the top too/wwwthreads_images/icons/laugh.gif). Hmmm........should I take that other D20 along???? Naw. It'll be fine. I'll let you guys know how the day goes tomorrow night.
Here's a pic before the skid plate went on,
Joe
....How do you imbed the pic right in the post, instead of an attachment????
Joe
