I have what appears to be two identical steering gear boxes, except the numbers on the front portion of the boxes are different. One has 689010, and is from another CJ. The other is 5689010 and is from an FS Cherokee.
I now know through researching for over a week trying to find if these stupid things are geared the same, that the box in the stock CJ's (689010) were 20:1 ratios. Is the one from the Cherokee (5689010) geared the same (=20:1,) higher (<20:1,) or lower (>20:1?)
If they are the same ratio, is the change in numbers due to a larger piston in the box off the Cherokee?
Or am I going nuts because I'm looking at the wrong numbers and the info I'm looking for is encoded elsewhere on the box?
If you know the answer, where did you find the info?
