Re: TeamRush\'s Dist upgrade
The bead of Silicone or even some Weather Strip Adhesive (gorilla snot) for a real moisture seal will work to firm things up.
Remember, you can do what you like with the cap base, because unless you damage it, it stays in place for the duration.
If you notice, the cap has a groove all the way around it that the cap base fits into, and a light bead of dielectric grease will seal that water tight also, and still allow removal with out being a pain in the butt.
If the cap and rotor are the only thing that gets changed...
Don't worry about the springs yet, that is another upgrade, and it isn't required at all if you don't want to.
Get the TFI coil and you should see some real changes in starting, idling and acceleration.
(Roll on power and acceleration will increase with a spring change! Just don't let it detonate, or spark knock)
Now you can jump straight to a CDI ignition without anymore changes other than the CDI module.
It's looking good! Why not Yellow plug wires?
Aaron.
I'm desperately trying to figure out why kamikaze pilots wore helmets...
Aaron.
