Guest
·The way they were removing the track pin, and variations on the same theme are unfortunately common in this industry. The proper way to remove a track pin is to use a hydraulic press. The correct tool looks like a big hydraulic "C" clamp. The track is cranked together using a special clamp to remove the tension of the chain from the pin and the press pushes the pin out. Simple, easy, and no one gets hurt. The procedure you described is far more common than the correct method. The likelyhood of hurting someone doing it this way is probably around 50%. Whether it be smashed fingers, the guy with the hammer falling off the track, or ?. It's too bad, it doesn't have to be this way. I refuse to assist the mechanic if he is going to do it improperly, but being union gives me the power to say no without being fired. Many don't have that option, and most probably don't know there is a safer way. The ironic part is that the right way is not only safer, it's much faster and easier.
The excavation industry, be it mining or construction, is dangerous enough. Some risks cannot be avoided, but the ones than can be minimized should be. BTW, in the U.S. the excavation industry averages one man killed every day, a man injured every 15 minutes.
Again, I am sorry about your friend and best wishes for his family.
My other car is a BULLDOZER
