I'd like to go to 3-wire stop/turn/tail lights...can anyone tell me how to do this? Right now it's 3 wires to the tail/stop lights and 2 to the turnsignals....
as always....thanks for the help
Gonna try my hand at building a rear bumper and want to use some of these oval grommet lights. Sorry if I wasn't clear enough. I'll check out the conversion boxes!
I used the same type of lights , but kept the original configuration of two brake , two turn, and two reverse lights . I did this after running the convertor for two years , I hated the fact that the 4-way flashers didn't show up correctly on the rear . They will not flash when you are on the brakes at all . So, when the new bumper was built , I went ahead and cut in 6 oval holes for the new grommet lights , love it and won't go back either . I did keep the convertor back there for the trailer hitch and set it up accordingly , works just fine .
Sarge
Sarge, would you have a pic of your bumper?? I'm trying to imagine 6 oval lights in that narrow space..must be wall to wall
Is there any metal left to bump into??
