Tail Lights - \'71 Commando
New to Jeeps. Purchased a '71 Commando a couple of months ago and I am trying to get everything working. Will be On and Off Road with it.
Found that the 1157 light bulb will not fit in the tail light socket properly. The base seems to be too long. This is the correct bulb according to the manual I have.
Does anyone else have this problem? Is there a fix?
I modified the socket by removing the spring, bottom insulator, and filing the connecting points in the socket and on the bulb down to get it in. It works, but it is pretty tight. I am concerned that it might break at the first big vibration through the frame when I hit that rock that's in my way.
Thanks,
Thanks,
