Hope someone else has had this problem. The light has gone out in my tachometer, which makes for a really dark dashboard.
I pulled off the dash panel, and decided I didn't want to rip out the tach without asking if this fix is possible or is it a 'sealed unit'.
btw. - 90 YJ.
Thanks in advance.
CursedJeep
HEY!! I have the exact same problem on my 88 i did the same thing i tore apart my dash to fix the bulb and its inside how do u fix it??
thanks
MIkey
(\/)ikey
When I bought my '88 both the tach and speedo were out, couldn't reach it from underneath so I pulled them out thru the front of the dash far enough to reach the twist knobs that hold the bulbs, there are 2 lights per instrument. Hope this helps.
Hey thanks a ton! I didn't want to yank it out for fear it may look tampered with. But if that does the trick,
they away we go.
