Guest
·I was wondering if the T-5 that's found in newer Jeeps and the T-5's that are say in the 87 and newer Mustangs ( world class T-5's )are about the same transmissions? I've decided on my 302 swap into my 84 CJ7, but I doubt my 4-speed transmission designed for the factory 4-cyl will hold up to V8 power. Since I'm using a Ford 302, could I just use the world class 5-speed that I got with the car also? I noticed that Advanced Adapters sells the adapter for this trans to Dana 300. Could I pull this adapter from a Jeep 5-speed? Or would the adapter that's currently on the Borg warner 4 speed that hooks to the dana 300 bolt up to the Borg Warner 5-speed and then just maybe change the main shaft? Would it work? Or am I stuck spending $600 on the adapter from AA? Anyone have any suggestions? I want the 5-speed over any 4-speed for highway and road use. No rock climbing for me. Thanks
Chad
Chad
