Guest
·We're gettin' ready to put a t-19/D20 combo out of a 78 Scout into a bro-in-laws CJ5 (It appears to be a 6.?:1 1st gear judging by the number of rotations to turn the rear shaft one full turn in 2 hi). The tranny has the long output shaft and deep bellhousing, so we're swapping in a Ford t-18 short shaft and redrilling his t-15 bellhousing. The question then comes down to the clutch and pressure plate...what do we use?? I don't have the Ford t-18 input shaft here yet and don't know its spline count. Will the pressure plate from the CJ's t-15 work? What clutch do we order/use? 4WD Hardware shows the same 10 1/2" x 1 1/8" 10 spline clutch for the t-15 and t-18s, so is the t-15 pressure plate and a new t-15 clutch interchangeable with the t-19 with a ford t-18 input shaft??
Any info or guidance would be appreciated. /wwwthreads_images/icons/smile.gif
Thanks,
Shain
Thanks,
Shain
