Coil Sprung D60
Ok, here goes.
First he used big square tubing to keep the axle in place, and mounted that using U-bolts. He had to grind down a little part of the right side of the axle on the bottom, more of a notch, so the inside U-bolt would fit flat. BTW, the U-bolts are mounted with the nuts going uo toward the oil pain of the engine. then he took probably 1 inch square tubing and welded it vertically beside the big square tubing, I believe that is called the trailing arm??, and comes up past the top of the trailing arm and then a piece of 1/4" flat steel was used as the mount for the coil. The coils still mount up top in the same place. He has a quad shock setup and they mount on top of the trailing arm. He says he would like to re-design the setup, because the stands he has look like he is trying to get an extra couple inches of lift. But he simmply has to get up over that big 4" in diamater square trailing arm.
Soon to have a truck, in about 2.5 months when I get the money.
