I have a stock '90 nissan 4x2 pickup. If I put the suspension from a nissan 4x4 pickup in my truck, would it give me the same clearance as the 4x4? if the clearance is the same, would an additional small body lift(2" or 3") give me enough room to run 31" tires? thanks for your help.
It should give you about the same clearance, but you might want to check the body-mounts and bushings etc, to see if they sit the same. Who know's with the 4X4 conversion you might even end up with more clearance???
Chris J.
/wwwthreads_images/icons/wink.gifIt's not the Biggest, but at least I use it!/wwwthreads_images/icons/wink.gif
