Survey: Which way does your CJ lean?
4.2K views 51 replies 17 participants last post by  **DONOTDELETE**
I was having a discusion with a fellow CJ owner about the notorious 'CJ Lean'.
So this got me to thinking...../wwwthreads_images/icons/crazy.gif
How many CJ's out there have it?
And which way is it leaning?
Mine always had a slight lean to the drivers side./wwwthreads_images/icons/smile.gif
#35 ·
Well I don't have a CJ anymore but I'll assume my other Jeeps count. My M38AI has a healthy lean to the passenger side. Possibly due to the engine residing where the passenger seat would normally be. I imagine that when the Heep reaches completion( which should be soon since the large pile of gravel that was blocking in my tranny has now moved) it'll lean which ever way there's a stiff breeze due to ultra squishy springs. My Commando is a diferent story. It's been relagated to storage shed duties and has 1 engine, 3 transmissions, and 3 transfer cases living in the back. These parts and the other Jeep debris in back cause it to lean about 4" to the rear. Happy Jeepin'
Travis
So many Jeeps... So little time/wwwthreads_images/icons/crazy.gif
#36 ·
Forward.
engine is too heavy for the springs....
Feel like you are going down hill all the time.
I'm considering doing SOA in the front only!! /wwwthreads_images/icons/wink.gif
#37 ·
(79 CJ) Drivers side BUT after suspension and bushing replacements it is now even /wwwthreads_images/icons/smile.gif
Jeff
Happy Owner of a 1979 CJ5
Almost finished /wwwthreads_images/icons/tongue.gif ( Ya Right ! )
There`s No Such Thing As Surface Rust
#39 ·
Maybe they just build them like that.or maybe they just do it to pi$$ ya off.
or maybe if your jeep don't look like it's leaning you had one too many beers.
Ray
why does everyone ask if I am gonna paint it ?
#42 ·
Ok, I'm a Wrangler guy so give me some slack but mine leans to the passenger side and sometimes seems like it sits straight. 176,000 and all stock (semi new shocks) 4.0 Auto. 1994. Give me another 100k is all I ask, lean or not. Starts with every turn and runs all day..... street or dirt.
#45 ·
I had a 1981 CJ-5 that leaned to the passenger side. I took it to a frame shop and was told that the frame was bent. Paid to have it fix and it was fine after that. My 1978 CJ-5 has no lean.
I think that most jeeps have bent frames, or at least bent springs, and probably both.
Kriss
#46 ·
Mine is a 1942 WWII GPW. Leans to the drivers side. I assumed it had a bent frame. It has 3" lift with new mody mounts. I installed a longer shackle on the left rear leafspring and now it sits level but looks odd from the rear.
#47 ·
I think most of the lean, assuming the frame isn't bent, is due to the offset of the engine, 1" or so to the driver's side on CJs, the driver's weight, and the fact that leaf springs have friction between each leaf that prevents the spring from fully recovering when you get out of the Jeep. (Just give the jeep a push after you get out, it will settle more level then!) YJs have the engine offset to the passenger side. TJs do too, but the coil springs have no friction holding them back. If you don't have a sway bar connected, the problem is worse. Heavier springs have less of a problem, also, as they are able to recover easier. The best solution is to have a slightly heavier spring on the front driver's side, this is what the Army spec'd out for the GPWs and MBs of WW2.
#49 ·
My scrambler leans to the passenger side which makes me happy since you hate to see it leaning worse with the driver in it towards the drivers side...... I had thought that it leaned to the drivers side, but I was mistaken....
#51 ·
OK...after reading this string for days...I'll be post #50. Wow!
My '72 CJ5 has a slight lean, definately noticable, to the driver's side. And yes, it leans with or without me in the vehicle.
"Pleased to meet you, hope you guess my name."
