I just lifted my 89 Bronco 6" using the Superlift suspension system with extended radius arms. The problem is, when I drive 10-20ft forward the front tires will become severely negative camber. I talked to several alignment shops and they said it was more then alignment problems. Has anyone else had this problem, and if so, what did you do to fix it? Any help will be appreciated, thanks!
