OK i know i should be able to figure this out right? Anyway my question lies in the way the bolts are supposed to go. for the tcase drop you need to remove all 4 bolts, and replace them with new longer ones, and spacers. I already have the kit, just haven't put it in yet. So on each side where the bolts are you have a bolt going up (hex head on bottom, nut on top) and you have a bolt coming down (nut on bottom, hex head on top) The ones coming up seem to be the easy ones, but where is the NUT>??? is it welded in there (and where is there), or will i need to fish it out and line it up to the bolt?
Now the ones coming down. I take the nut off right- then how do i get the bolt out, where is the little bastard, hopefully it's not welded in, how would i get the new one in there. I know a bunch of you have done this, so let me know. I'm pretty lucky at 5ish inchs have hace ZERO vibs, but i wanna get it in there before i get to the 7".
Thanks Guys,
Todd
88' XJ
3" rusty's
1.75" Shackles
2" RE spacers.
Rusty LCA's.
RE extended slip yoke.
RE adj trackbar
Quadratec SS Brakelines
31" goodyear wrangler at's
Sway-bar disco's
Thanks Guys,
Todd
88' XJ
3" rusty's
1.75" Shackles
2" RE spacers.
Rusty LCA's.
RE adj trackbar
Sway-bar disco's
