There is a sender low on the passenger side block. There is a sender high on the drive side head (or close to it). '78 258. Which one is the oil sender and which the temp sender? Yeah i know dumb question./wwwthreads_images/icons/smile.gif - Tim
the lower one on the block, that looks sort of like a bell, is the oil pressure sender.
The one higher up on the head is the coolant temperature sender.
Mark
83 CJ-7 and 76 CJ-7 with stuff
the one on the block (passenger side) is the oil pressure sender.
the one on the head (driver side) is the temp guage.
I suggest changing them both out to manual gauges. Neither one of mine worked when I got my Jeep. So i went to manual because they are much more accurate and reliable than the stock electric ones.
'79 CJ-5
Sentinel,
How hard is the switch to manual guages, lots of work involved? What brand did you use?
TEXAS1AL
84 CJ-7; 258 I6; Restored-to-Stock Condition
