I have made a very stupid mistake of buying a explorer procrap......I know I know!!! I was just wondering if there is anything that I can do to soften up the right so it doesnt bounce as much and so I dont have to keep extra sports bras in my jeep for my passengers
1. Greasable shackle and main spring eye bolt/bushings
2. Strip the springs, repaint with hamerite, and reassemble with teflon pads
3. Get new shocks - try Rancho RS9000's for $52 each (+ $5 s/h) Hotrod Offoad
4. Get used to it (you did after all buy a Jeep)
5. Capitolize on the opportunity - I saw a CJ 'round town here with the following license plate - "TTJGGLR"
Just some ideas.... Happy Jeepin'!
-Spyder
Sorry, to hear about your purchase. I have the same 2-1/2" kit on my CJ7. It really rides like Crap. I have greasable shackles and the ES3000 shocks that came with the kit. To improve my ride I built a set of heavy bumpers and I run my tires at a pretty low PSI. I am hoping to get a set of Superlift Superride springs, but probably not any time soon. I have been told that new shock probably won't make that much difference, it is the springs that suck.
TOM85CJ7
1985 CJ7 4.2L, T-176, Dana 300, 2.5" lift, 32"BFG MT, Durabak On-Board Air
I have a 2 1/2" procomp for my YJ and after about a year it settled down and it rides pretty nice now....but the first couple of months were pretty bad..so there is hope.
absolutjeep
Actually, if you have some heavy stuff, the Pro-Comp springs are the way to go, softer ones would sag. I have a winch, hi-lift and
33 inch spare, so for me the ride is OK. Also, I tow a Packmule trailer for camping, along with a loaded Jeep I'm actually glad I have
the heavier springs.
6. Make sure your shackles aren't too tight. The factory torque specs are too tight.
7. Better option than number 2 (if you can find this stuff), is graphite paint. Farm supply stores should have it.
8. Listen to us the next time we warn you away from a product /wwwthreads_images/icons/wink.gif
Official Historian
i have the 4 inch cj kit and for the first few weeks it rode hard too. after a few trips flexing them, they softened a little. before i ordered it i called for the spring rates. the 4 inch had a lower spring rate than the 2 1/2 inch in the front which influenced my decision between them. the rears are the same spring rate. here are the numbers that pro-comp gave me:
_____2 1/2_____4
front 325 lb/in 290 lb/in
rear 250 lb/in 250 lb/in
i put rs5000s in the front and they are better than the shocks that came with the kit. i haven't gotten around to doing something with the back yet. i just swapped in a dana 44 and am using the shocks from the kit and the spring plate mount. i might be welding the axle mounted shock mount back on. i had to remove it because the spring pads needed to occupy that space.
