1 - 14 of 14 Posts
I'd like to get some recommendations on the best way to remove the plactic coating on my stock cj chrome rims. The plastic is flaking off and looks like crap.
/wwwthreads_images/icons/tongue.gif A good way to always be able to spell some of those chemical derivitives is to use this method: Acetylene is "Ace" "Tylene" and Acetone is "Ace" Tone". Learned that from making out a zillion Purchase Orders for cylinders of acetylene from the welder's supply./wwwthreads_images/icons/wink.gif That's when every thing I owned had holes burned in it./wwwthreads_images/icons/crazy.gif Now I only weld on Jeeps./wwwthreads_images/icons/cool.gif
You see, elusive, Dave had a bug about spelling a few months ago, and he WILL NOT let you get away with it. But, while I'm at it,
Dave, it's YOKE not yolk! /wwwthreads_images/icons/laugh.gif
Looks like the jolk's on you, Dave.
D-O-O-O-H-H-H-H.......
Loose nut behind the wheel
Born and raised in Jeep-Town
I've tried a little spot with fingernail polish remover/acetone and it didn't seem to work very well. It only made the plastic softer instead of dissolving it.
you can try to heat it with a torch, and see if it will peel away. Just dont get too close to the chrome or it will start to blue. /wwwthreads_images/icons/smile.gif /wwwthreads_images/icons/smile.gif /wwwthreads_images/icons/smile.gif
Official Curmudgeon
If we're going to get into a spelling bee, I'm outta here. Does remind me though of a guy I was in the
service with. His girl back home was an english major. She sent his best love letters back with
spelling, grammar and punctuation corrections. Now that's cold.
Discussion Starter · #12 ·
Depends on what type of paint stripper. For the most part chrome is pretty tuff stuff, you might try a water soluble paint stripper or maybe some aircraft finish remover. Just dont get the stuff on your skin. I think you should try to heat it up a little and see if it will just flake off. I actually dont do much re-chroming, but I do alot of chrome work and I think that heat my be something to try. Just be careful.
Discussion Starter · #13 ·
dave, i just used paint stripper on my rims last weekend and it worked great.
went to home depo and got a quart of the strong stuff and scrubbed it off with a scrubrush. wear gloves had to repeat a second time to get it all off
it didn't hurt the chrome a bit
Discussion Starter · #14 ·
I remeber my first experience using acetone. I was using it to take off some paint, had gloves on and all, but I poured it in a plastic container so I coud dip a sponge and brush in it. Very dumb. The acetone ate its way through the plastis and before I knew it I was standing in a puddle of acetone and it had already started working its way through my shoes.
1 - 14 of 14 Posts
